TwinTurbo.NET: Nissan 300ZX forum - Re: You need to get a timing light on it and check it.
rhombicblue
on July 12, 2012 at 12:47 PM
posted by Draker (Eugene, OR)
on July 12, 2012 at 10:45 AM
When you have ignition timing checked, also verify that slotted bolt on CAS is approximately in the middle of the slot. If the slotted bolt is at either end of the slot, belt may not have been installed correctly.
Timing Belt Replacement... HELP!
CalebsZ
17:08:28 07/11/12
If the car before ran good, it should come out from the
CmyZ
17:30:44 07/11/12
They goofed up your timing.
sandmanz32
17:51:00 07/11/12
What reading does a timing light give? Maybe worth the
jzack
18:29:09 07/11/12
Yeah your timing is off (n/m)
z-u-later
20:07:53 07/11/12
Re: Timing Belt Replacement... HELP!
ALee
23:53:40 07/11/12
Draker (Eugene, OR)
10:45:07 07/12/12
Re: You need to get a timing light on it and check it. -
rhombicblue
12:47:51 07/12/12
sounds like jumped a tooth.. didnt set it up correctly. (n/m)
Drk93TT
16:20:20 07/15/12
